While installing SW Electrical we can install SQL with the SW Electrical but also with EPDM comes SQL installation So to be sure for healthy installation process for both :
- Which SQL should I install first (or which product should I install first) ?why ?
- the SQL that comes with the SW Electrical is express , what about the one that comes with EPDM ?
- can I use the SQL that comes with the SW Electrical to set up EPDM Server ?
- can I use the SQL that comes with EPDM to set up SW Electrical Server ?
Thank you in advance.
1. It doesn't matter, as the SQL with Electrical is an express version it will install it's own instance.
2. EPDM has an OEM version of SQL 2008 R2, I think it's SQL standard. You are only allowed to use it for EPDM databases.
3. Yes, but that will probably limit the memory usage of the database too much for EPDM.
4. No, the license does not allow that.
