3 Replies Latest reply on Feb 10, 2015 8:59 PM by Hernan Dario Patino Duque
    How to inserts a symbol into a  note with API.
    Yong Ning
      Private Sub LL()
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
          Set SwApp = GetObject(, "SldWorks.Application")
          Set SwModel = SwApp.ActiveDoc
          Set SwDraw = SwModel
        Dim SwSelMgr As SelectionMgr, SwNote As Note
          Set SwSelMgr = SwModel.SelectionManager
          Set SwNote = SwSelMgr.GetSelectedObject2(1)
          Debug.Print SwNote.GetText
        • Re: How to inserts a symbol into a  note with API.
          Jim Sculley
          If you know what symbol you want, you can simply call SetText with the appropriate tag added to the value returned from GetText.
          You can determine the tag to use by creating a note that looks the way you want and then right clicking and selecting Edit Text In Window which will show you the tags:
          Jim S.
            Yong Ning
            Private Sub ll()
                 Set SwApp = Application.SldWorks
                 SwModel.ClearSelection2 True
              Dim SwDraw As DrawingDoc
              Dim SwFeat As Feature, SwView As View
                 Set SwFeat = SwDraw.FeatureByName("浮头管板Dn700右视图")
                 SwFeat.Select True
                 Set SwView = SwSelMgr.GetSelectedObject5(1)
              Dim SwNote As Note, NoteName
              Dim SwAnn As Annotation
                 'Set SwNote = SwDraw.InsertNote("fffff")
                 'Debug.Print SwNote.GetName
                 'SwNote.SetName "aaa"
                 NoteName = "aaa@" & SwView.GetName2
                 boolstatus = SwDraw.Extension.SelectByID2(NoteName, "NOTE", 0, 0, 0, False, 0, Nothing, 0)
                 If boolstatus Then
                   Set SwNote = SwSelMgr.GetSelectedObject5(1)
                   Set SwAnn = SwNote.GetAnnotation
                   ss = SwView.GetOutline
                   SwAnn.SetPosition ss(2), ss(3), 0
                 Stop
