4 Replies Latest reply on May 22, 2014 3:50 PM by Michael Ferraro
    What is this Code?
    Michael Ferraro
      Hello All,
      I am in the process of attempting to create a macro and I have taken another macro with a similar function and am attempting to tweak it as necessary.
      Could anyone tell me what the following few lines of code are actually doing?
      Dim swDocTypeLong As Long
      ext = UCase$(ext)
      swDocTypeLong = Switch(ext = ".SLDDRW", swDocDRAWING, True, -1)
      If swDocTypeLong = -1 Then
      Exit Sub
      Thank you very much!
      Pencil
        • Re: What is this Code?
          Patrick O'Hern
          ext = UCase$(ext)  - I'm assuming "ext" has been defined elsewhere in the code to be the file extension.  This line is setting it to be uppercase
          swDocTypeLong = Switch(ext = ".SLDDRW", swDocDRAWING, True, -1) - This is checking to see if the file extension is for a Drawing.  If it is, then "swDocTypeLong" is set to match a drawing document, otherwise it is set to "-1".
          If swDocTypeLong = -1 Then  -  This is checking to see if "swDocTypeLong" was set to "-1" in the previous line
          Exit Sub  - This exits the sub if the previous line was true
          You could do the same thing by using:
          If UCase$(ext) = ".SLDDRW" Then
               swDocTypeLong = swDocDrawing
          Else
               swDocTypeLong = -1
               Exit Sub
          Or you could simplify it even more if swDocTypeLong is only being used in this sub:
          If Not UCase$(ext) = ".SLDDRW" Then
               Exit Sub
