in a sectioned assembly
when i add a part by dragging from another window.
The part dissapears and i have to close the section move the part and then resection. oh well.
John,
I don't think it ever a good idea to insert a part into an assembly with the section view turned on. You should at least do one mate to tie it to the other parts before doing the section. It makes sense you cannot see it since a section view is cutting it away. If you were to drag it to the side of the section view not being cut it will show up again.
Chris
Statement or ?
