3 Replies Latest reply on Jun 14, 2014 11:43 AM by Deepak Gupta
    SW macro to toggle a SW files windows read only attribute
    Grant Baugh
      Is it possible to have a SW macro to toggle a SW files windows read only  attribute?  Basically can a macro check and uncheck the read only state  in Windows?  We keep our fasteners as read only in Windows but  occasionally we have to edit them so we have to browse to the file right  click and uncheck "read only".  When done editing we have to recheck  "read only".  Trying to condense that down to only having to click a  macro once we have the file open.
        • Re: SW macro to toggle a SW files windows read only attribute
          Ivana Kolin
          yes it is possible
          you can use vba statement SetAttr
          SetAttr "TESTFILE", vbHidden ' Set hidden attribute.
          ' Set hidden and read-only
          ' attributes.
          SetAttr "TESTFILE", vbHidden + vbReadOnly
          or  Scripting.FileSystemObject
          Function MakeFileReadOnly(ByVal sFile As String)
              Dim strSaveFilename As String
              Dim oFSO As Object
              'Scripting.FileSystemObject Dim oFile As Object
              'Scripting.File
              ' Create Objects
              ' Uses Late Binding
              Set oFSO = CreateObject("Scripting.FileSystemObject")
              Set oFile = oFSO.GetFile(FilePath:=sFile)
              'Set file to be read-only
              oFile.Attributes = 1
              ' Releasing Objects
              If Not oFSO Is Nothing Then Set oFSO = Nothing
              If Not oFile Is Nothing Then Set oFile = Nothing
          End Function
            Deepak Gupta
            Yes it can b e done but the file will have to be closed IMO to set the attributes from readonly to normal and then back to readonly.
            With that said, it all can be done via a macro i.e. once you activate the file (make it current active file) and run the macro. Then macro would close it, remove readonly and open it again. You make the changes and then macro will close it, set to readonly and open again. I should mention that macro would keep running in the background and would wait until you close it to process further.
