2 Replies Latest reply on May 22, 2014 12:02 AM by Vincent Li
    Renamed the component name , and found wrong name under pattern feature in assembly design tree?
    Vincent Li
      Dear Master Shi Fu,
      when I Renamed the component name , and found wrong name under pattern feature in assembly design tree, using the macro sample in the API help.
      But the result showed that the component names under the pattern feature are wrong , we hope it they are the same.
      you may check the attached picture. How to handle it ? pls help to advise.
      Dim swapp                   As SldWorks.SldWorks
          Dim swmodel                 As SldWorks.ModelDoc2
          Dim swConfigMgr             As SldWorks.ConfigurationManager
          Dim swConfig                As SldWorks.Configuration
          Dim swRootComp              As SldWorks.Component2
          Dim Children                As Variant
          Dim swChild                 As SldWorks.Component2
          Dim ChildCount              As Integer
          Dim OldName                 As String
          Dim NewName                 As String
          Dim bOldSetting             As Boolean
          Dim bRet                    As Boolean
          Dim i                       As Long
          Set swapp = Application.SldWorks
          Set swmodel = swapp.ActiveDoc
          Set swConfigMgr = swmodel.ConfigurationManager
          Set swConfig = swConfigMgr.ActiveConfiguration
          Set swRootComp = swConfig.GetRootComponent
          bOldSetting = swapp.GetUserPreferenceToggle(swExtRefUpdateCompNames)
          swapp.SetUserPreferenceToggle swExtRefUpdateCompNames, False
          Children = swRootComp.GetChildren
          ChildCount = UBound(Children)
          For i = 0 To ChildCount
              Set swChild = Children(i)
              ' Changing component name requires component to be selected
              bRet = swChild.Select2(False, 0)
              OldName = swChild.Name2
              NewName = OldName & "_" & UserForm1.TextBox1.Text
              Debug.Print "OldName = " + OldName
              Debug.Print "NewName = " + NewName
              Debug.Print ""
              swChild.Name2 = NewName
          Next i
          swapp.SetUserPreferenceToggle swExtRefUpdateCompNames, bOldSetting
