Is it common to have to rebuild each configuration of a part
file? What's happening is I have noticed that some of my standard
part files need updating and I am confused as to why. For example,
my washer part file, which has been in my library for years as read
only needs to be saved when I open it up and switch configs. I am
able to recreate this issue with brand new part files also. The
little * appears after the file name on the title of the window for
parts just by switching configs. These are parts that have no
external refs, no equations, and no design tables. I can make the
problem go away by traversing thru each config and rebuilding and
then saving the part. This seems a little silly to me considering
the amount of time a person would have to spend if you have a part
file that had a hundred or so configs.
BTW, I sent my corupt part to VAR who in turn forwarded to SW for review/repair so I could insert the design table a couple months back...still have yet to hear from them on this. I found that whenever I send a part off to SW tech support, you very seldom hear back on anything and due to attrition finally give up and just redraw the parts anyway.
John
