I have a problem where the scroll function on my mouse becomes uncontrollable at seemingly random times. Most times the behaviour is what you might expect, moving the scroll wheel gives a proportional zoom on the screen.
However, on occasion, moving the scroll wheel a very small amount will cause the view on the screen to either zoom to a point on the screen or all the way in. The only fix for this seems to be restarting SW (PITA).
Does anybody have a root cause for this? Or maybe even just a work-around?
I did see where someone else posted a similar issue for a Spacemouse but I haven't had an opportunity to try the work-around from that post although I'm not entirely certain I understand it not having had a chance to experience it and then try the fix. Is it simply selecting a predefined view orientation which causes the mouse scroll wheel zoom factor to reset???
I have replaced my mouse (for other reasons as well) without success. I speculate that having dual monitors and switching back and forth between applications may be a factor but it isn't anything I can reproduce.
MJK
