9 Replies Latest reply on Aug 4, 2014 10:00 AM by Deepak Gupta
    Macro writing into configuration specific properties
    Petr Skotnica
      This macro writes a part of filename into custom properties. I need to write the same into configuration specific properties.
      Could anyone help?
      Option Explicit
      Dim swApp           As SldWorks.SldWorks
      Dim swModel         As SldWorks.ModelDoc2
      Dim swCustPropMgr   As SldWorks.CustomPropertyManager
      Dim FILENAME        As String
      Dim PartNo          As String
      Dim Description     As String
      Dim PartTitle       As String
      Set swModel = swApp.ActiveDoc
      Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
      FILENAME = swModel.GetTitle
      PartNo = Left(FILENAME, 13)
      Description = Mid(FILENAME, 15)
      Dim a As String
      FILENAME = Replace(Replace(FILENAME, ".sldprt", "", , , vbTextCompare), ".sldasm", "", , , vbTextCompare)
      swCustPropMgr.Add2 "PartNo", swCustomInfoText, " "
      swCustPropMgr.Set "PartNo", PartNo
      swCustPropMgr.Add2 "Description", swCustomInfoText, " "
      swCustPropMgr.Set "Description", Description
