0 Replies Latest reply on May 19, 2014 12:13 PM by Doug Foote
    Quickview (RapidDraft) opening Issue
    Doug Foote
      Hello All...
      I have an applicatioin that has been running for sometime that opens a SolidWorks File and then does a save-as to a PDF.  This runs without issue.  Recently I changed the open string to open as a "Quickview" drawing.   The purpose of this was to remove the need to have all model and assembly support copied to same location as draiwng.
      With Quickview there is no Save-As to PDF but I can plot to an Adobe Printer to get the desired results.
      My Issue:
      Not ALL SolidWorks drawings are able to be opened in a Quickview Mode.  I am unable to detemine why some drawings work and others do not.  What I end up doing it trapping the error, which is = 1 (general error), and then open the drawing again with full model support.  This sort of defeats my project of removing all model support.
      Here is the string I am using to open the drawing:
          Set SldMD = swApp.OpenDoc6(FullFile, swDocDRAWING, 1 + 2 + 8, vbNullString, nErrors, nWarnings)
      I have tried variations of the swOpenDocOptions.
      Any help would be greatly appreciated.
