3 Replies Latest reply on Jun 12, 2014 5:56 AM by Santosh Pawar
    Create SpeadPack automatically Using API
    Rami Noah
      I have posted this query also in Asseblies discussion = Sorry for the hassle.
      like all we having some issues with large assemblies preformance.
      one off the new technique i'm about to implement is SpeadPack.
      what i would like to advice with you is the necessety and advantage of writing adedicated utility, using API, for
      creating default speadpack for high-levels asms.
      any special recomandation for ? something in specific to watch\check ?
      does SW have such a tool already in place in task scedualre or somewhere else ( partners / self development )?
      Many thanks,
      Ram
        • Re: Create SpeadPack automatically Using API
          Manikandan Babu
          Dear Rami,
                              Run this macro in Toplevelassembly ,it will create default speedpak every subassembly which is present in toplevel.
          Option Explicit
          Dim swmodel As SldWorks.ModelDoc2
          Dim swassembly As SldWorks.AssemblyDoc
          Dim vcomp As Variant
          Dim i As Integer
          Dim j As Integer
          Dim comp As SldWorks.Component2
          Dim error As Long
          Dim warning As Long
          Dim assemblytitle As String
          Dim ConfigMgr As SldWorks.ConfigurationManager
          Set swmodel = swApp.ActiveDoc
          Set swassembly = swmodel
          assemblytitle = swmodel.GetPathName
          vcomp = swassembly.GetComponents(True)
          For i = 0 To UBound(vcomp)
              Set comp = vcomp(i)
              swApp.OpenDoc6 comp.GetPathName, 2, 0, "", error, warning
              swApp.ActivateDoc2 comp.GetPathName, True, error
              Set ConfigMgr = swmodel.ConfigurationManager
              ConfigMgr.AddSpeedPak2 2, 0.5
              swApp.CloseDoc swmodel.GetTitle
          Next
              For j = 0 To UBound(vcomp)
                  Set comp = vcomp(j)
                  comp.ReferencedConfiguration = "Default_speedpak"
              Next
              Set swmodel = swApp.ActivateDoc2(assemblytitle, True, error)
              swmodel.ForceRebuild3 True
              swApp.SendMsgToUser ("Speedpak completed")
          Manikandan
          EGS Computers India Pvt Ltd
          http://www.egsindia.com
          http://www.egs.co.in
