Set variable to data card for multiple roles during parallel transition
Question asked by Victor Sardinas on May 19, 2014
Latest reply on May 20, 2014 by Victor Sardinas
Afternoon,
Found  this Discussion in the Forum: Set variable to data card for multiple roles during parallel transition
1. Using A Parallel Transition to get approvals in Workflow
2. Using Dispatch script to test for user and transfer to data card
Problem:
First, I am not a programmer, I know a little, so please be kind... Second, I would like to thank all of the people whom have supplied examples and help with Dispath.
If CheckedBy goes first, data card will look like Drawing Card First Signature, then Drawing Card After Second Signature is how the card should look (correct), but if admin goes first, admin will be on both fields, and CheckedBy is ommited.
I thought if I used the jump command with a LABEL, it would go to the right section in the program. Not sure what I am doing wrong.
Thank you again,
vsardinas
