1 Reply Latest reply on Jun 19, 2014 12:28 PM by Jacob Corder
    have Dimension → How to set DisplayDimension?
    Yong Ning
      Have DisplayDimension → set  dimension → use sentance →
      Set SwDim = DispDim.GetDimension
      (Dim DispDim As DisplayDimension, SwDim As Dimension)
      question
      Have dimension → how to set displaydimension
      follow cde , use feature set displaydimension
      Private Sub del0519_1()
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
          Set SwApp = GetObject(, "SldWorks.Application")
          Set SwModel = SwApp.ActiveDoc
        Dim SwSelMgr As SelectionMgr, SwFeat As Feature
          Set SwSelMgr = SwModel.SelectionManager
          Set SwFeat = SwSelMgr.GetSelectedObject5(1)
          'Debug.Print SwFeat.Name
          Set SwDim = SwModel.Parameter("D1@阵列")
          Debug.Print SwDim.FullName, SwDim.Value
          Set DispDim = SwFeat.GetFirstDisplayDimension
          Debug.Print DispDim.GetText(1)
          Set DispDim = SwFeat.GetNextDisplayDimension(DispDim)
          DispDim.SetText 1, Replace(DispDim.GetText(1), "XX", SwDim.Value)
        • Re: have Dimension → How to set DisplayDimension?
          Jacob Corder
          There is a way to do it but as far as i know i think you will have to get all DisplayDimensions
          Go through each one to get all of their dimensions using IDisplayDimension.GetDimension2
          Public Function GetDisplayDimension(ByVal ThisDimension As Dimension, ByVal DisplayDimensionsToCheck() As DisplayDimension) As DisplayDimension
                  Dim RetDim As DisplayDimension = Nothing
                  For i = LBound(DisplayDimensionsToCheck) To UBound(DisplayDimensionsToCheck)
                      Dim CompareDimension As Dimension = DisplayDimensionsToCheck(i).IGetDimension
                      If ISwapp.IsSame(CompareDimension, ThisDimension) = swObjectEquality.swObjectSame Then
                          RetDim = DisplayDimensionsToCheck(i)
                          Exit For
                  Next
                  Return RetDim
              End Function
