1 Reply Latest reply on May 18, 2014 4:37 AM by Deepak Gupta
    How do I remove hardcoded values from macros?
    Neville Bonwit
      I recorded a macro, but it has all sorts of hardcoded propterties in it instead of variables.
      After clicking on a part in an assembly, the user will start the macro.  The macro should:
      1) Open the selected part
      2) Go to Configurations->Properties
      3) Change the Bill of Materials Part Number to "Document Name"
      4) Go back to the Design Tree
      5) Save and close the file
      Please let me know what variables I should use to replace the 7 items in bold below.
      Thank you!
      ' Autogenerated Macro code
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Set swApp = _
      Application.SldWorks
      Set Part = swApp.ActiveDoc
      'boolstatus = Part.Extension.SelectByID2("McM 91841A011 Nut-1@Segment Cutter Roller", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
      Part.OpenCompFile
      'Set Part = swApp.OpenDoc6("C:\Users\...\_CAD\COTS\McM 91841A011 Nut.SLDPRT", 1, 0, "", longstatus, longwarnings)
      Dim myModelView As Object
      Set myModelView = Part.ActiveView
      myModelView.FrameLeft = 0
      myModelView.FrameTop = 0
      myModelView.FrameState = swWindowState_e.swWindowMaximized
      swApp.ActivateDoc2 "McM 91841A011 Nut.SLDPRT", False, longstatus
      Part.ClearSelection2 True
      boolstatus = Part.Extension.SelectByID2("91841A011", "CONFIGURATIONS", 0, 0, 0, False, 0, Nothing, 0)
      boolstatus = Part.EditConfiguration3("91841A011", "91841A011", "10-24", "", 32)
      Set Part = Nothing
      swApp.CloseDoc "McM 91841A011 Nut.SLDPRT"
      swApp.ActivateDoc2 "Segment Cutter Roller.SLDASM", False, longstatus
