4 Replies Latest reply on Jun 8, 2014 11:37 PM by Vishaldeep Singh
    i want to make two 3d sketch
    Vishaldeep Singh
      hello
      in the attachment there is excel file and macro file.
      there is a special symbol "$" in the  excel sheet and i want upto $ sign the point must generate in 1st 3d sketch and after $ sign the points should generate in 2nd 3d sketch
      so my question is is this thing possible in macro coding.
        • Re: i want to make two 3d sketch
          Ivana Kolin
          Option Explicit
          Dim swSketchMgr As SldWorks.SketchManager
          Dim swExcel As Excel.Application
          Dim exSheet As Excel.Worksheet
          Dim i As Integer
          Dim sVal As String
          Dim xpt As Double
          Dim ypt As Double
          Dim zpt As Double
              Set swModel = swApp.ActiveDoc
              Set swExcel = GetObject(, "Excel.Application")
              Set exSheet = swExcel.ActiveSheet
              Set swSketchMgr = swModel.SketchManager
              Dim skPoint As SketchPoint
              swSketchMgr.AddToDB = True
              swSketchMgr.Insert3DSketch False
              i = 1
              Do While exSheet.Cells(i, 1).Value <> ""
                  sVal = exSheet.Cells(i, 1).Value
                  If sVal = "$" Then
                      swModel.ClearSelection2 True
                  Else
                      xpt = exSheet.Cells(i, 1).Value
                      ypt = exSheet.Cells(i, 2).Value
                      zpt = exSheet.Cells(i, 3).Value
                      xpt = xpt * 0.001
                      ypt = ypt * 0.001
                      zpt = zpt * 0.001
                      Set skPoint = swSketchMgr.CreatePoint(xpt, ypt, zpt)
                  i = i + 1
              Loop
              swSketchMgr.Insert3DSketch True
              swSketchMgr.AddToDB = False
              Vishaldeep Singh
              sir is this code work for curve also? could you please suggest me the modification in this code for curve..
              Dim i As Integer
              Dim sVal As String
              Dim xpt As Double
              Dim ypt As Double
              Dim zpt As Double
                 Set part = swApp.ActiveDoc
              part.AddToDB = True
              part.InsertCurveFileBegin False
              i = 1
                      If sVal = "$" Then
                          part.ClearSelection2 True
                      Else
                      xpt = xpt * 0.001
                          ypt = ypt * 0.001
                          zpt = zpt * 0.001
                      boolstatus = part.InsertCurveFilePoint(xpt, ypt, zpt)
                  i = i + 1
                  Loop
                  boolstatus = part.InsertCurveFileEnd True
                  part.AddToDB = False
                  Deepak Gupta
                  Try these:
                  Dim i As Integer
                  Dim sVal As String
                  Dim xpt As Double
                  Dim ypt As Double
                  Dim zpt As Double
                  swModel.InsertCurveFileBegin
                  i = 1
                          If sVal = "$" Then
                              swModel.InsertCurveFileEnd
                          Else
                          xpt = exSheet.Cells(i, 1).Value * 0.001
                          ypt = exSheet.Cells(i, 2).Value * 0.001
                          zpt = exSheet.Cells(i, 3).Value * 0.001
                          boolstatus = swModel.InsertCurveFilePoint(xpt, ypt, zpt)
                      i = i + 1
                      Loop
                      boolstatus = swModel.InsertCurveFileEnd
