Hi, today in class we were doing the anslysis of a mouse that we have modelled, but when I tried to do the undercut analysis it didn't did well like to the others in class, and after I closed the PropertyManager, the analysis results did not remain visible in the graphics area, as it should be.
This problem occured just in two pcs, my and my teacher. He was using the 2010-2011 education version like most people in class(network installation) and I was using my own laptop with sw 2010.The file was the same, modelled by our teacher. He also didn't know why, because in his laptop it worked well.
The purpose of this was to mantain in the grafic area the results, so that we could draw a new parting surface to divide the top part of the mouse from the botton part, avoiding undercuts.
Can someone help?
Most likely the problem is the graphics card or graphics card driver on your laptop (and on the other pc that had the problem). I commonly encounter the problem you describe when I am using a computer with a low-end graphics card.
Also, I personally find the Undercut Analysis tool to be rather uselss...Draft Analysis (with the angle set to 3 deg and the "Gradual transition" box checked...and negative draft color set to blue) tells me everything that Undercut Analysis does and a whole lot more. But both of these tools require a good graphics card to work correctly.
