8 Replies Latest reply on May 25, 2014 3:15 AM by Deepak Gupta
    3d line
    Vishaldeep Singh
      hello
      i want to create a line with co-ordinate
      x1=50mm, y1=50mm, z1=50mm
      x2=100mm, y2=100mm, z2=100mm
      i recorded a macro but when i put the above values and run the macro in the output only the x,y values are there and z value is 0 means the output is coming in xy plane.
      for this i recorded a macro to create 3d sketch.
        • Re: 3d line
          Deepak Gupta
          Works fine for me. Here are the macro codes
          Option Explicit
              Dim swApp                   As SldWorks.SldWorks
              Dim swModel                 As SldWorks.ModelDoc2
              Dim nPtData(6)             As Double
              Dim swSketchSeg             As SldWorks.SketchSegment
              Set swModel = swApp.ActiveDoc
              'Values should be in meter. In case you want MM then divide values by 1000 as shown below.
              nPtData(0) = 50 / 1000
              nPtData(1) = 50 / 1000
              nPtData(2) = 50 / 1000
              nPtData(3) = 100 / 1000
              nPtData(4) = 100 / 1000
              nPtData(5) = 100 / 1000
              swModel.Insert3DSketch2 True
              Set swSketchSeg = swModel.CreateLine2(nPtData(0), nPtData(1), nPtData(2), nPtData(3), nPtData(4), nPtData(5))
            • Re: 3d line
              Vishaldeep Singh
              Thank you so much sir...
              • Re: 3d line
                Ar K
                If you forced to (because  some features don't accept 3DSketch) using  " swModel.InsertSketch2 "   for drawing a line between p1(x1,y1,z1) and p2(x2,y2,z2)
                i think you must using :
                IRefPlane::Transform
                ISketch::ModelToSketchTransform
                • Re: 3d line
                  Vishaldeep Singh
                  sir is this coding will work for curve instead of points.
                  what will be changes then...
                    • Re: 3d line
                      Deepak Gupta
                      Option Explicit
                          Dim nPtData(9)              As Double
                          Dim vPtData                 As Variant
                          nPtData(3) = 200 / 1000
                          nPtData(4) = 150 / 1000
                          nPtData(5) = 120 / 1000
                          nPtData(6) = 150 / 1000
                          nPtData(7) = 350 / 1000
                          nPtData(8) = 150 / 1000
                          vPtData = nPtData
                          Set swSketchSeg = swModel.CreateSpline(vPtData)
                        • Re: 3d line
                          Vishaldeep Singh
                          that is ok but sir i specifically need a curve command
                          • Re: 3d line
                            Vishaldeep Singh
                            not working
                            Dim swSketchMgr As SldWorks.SketchManager
                            Dim swExcel As Excel.Application
                            Dim exSheet As Excel.Worksheet
                            Dim i As Integer
                            Dim sVal As String
                            Dim xpt As Double
                            Dim ypt As Double
                            Dim zpt As Double
                               Set part = swApp.ActiveDoc
                                Set swExcel = GetObject(, "Excel.Application")
                                Set exSheet = swExcel.ActiveSheet
                                Set swSketchMgr = swModel.SketchManager
                            part.AddToDB = True
                            part.InsertCurveFileBegin False
                            i = 1
                                Do While exSheet.Cells(i, 1).Value <> ""
                                    sVal = exSheet.Cells(i, 1).Value
                                    If sVal = "$" Then
                                        part.ClearSelection2 True
                                    Else
                                    xpt = exSheet.Cells(i, 1).Value
                                    ypt = exSheet.Cells(i, 2).Value
                                    zpt = exSheet.Cells(i, 3).Value
                                    xpt = xpt * 0.001
                                        ypt = ypt * 0.001
                                        zpt = zpt * 0.001
                                    boolstatus = part.InsertCurveFilePoint(xpt, ypt, zpt)
                                i = i + 1
                                Loop
                                boolstatus = part.InsertCurveFileEnd()
                                part.AddToDB = False
