I set up a problem with water and got some reasonable value, but once i change the fluid to olive oil, the values become unrealistic. I'm not sure what i'm missing can someone explain why Flow Simulation does this and what needs to be done to fix it?
What is unrealistic?
What is the problem setup? Is it simple enough to hand calc for comparison?
What are you comparing the solution against?
