When i rotate the assebly, all the pieces shake and when i stop rotating all the pieces stays not in the correct place but any mate broken.
I am working on a large assembly with many pieces, also working with the routing feature. I was working just fine with the tubing routing and everything work just fine. When i started using the electrical routing feature i had an error but i fixed it, then after that the problem occured. I tried to fix it by reducing the options of display as quallity and resolution in settings.
I restarted the computer and also many times the solidwokrs. I tred to rebuild the assambly but any errors apear (mostly mates problems but all the assambly is ok). I deleted the electrical routing which i thought it was the problem but still not fix the assembly.
How can i fix this in my computer??
I have had that happen but it always fixed when I restarted SolidWorks. I'd suggest running the SolidWorks Rx diagnostics and see if your graphics card driver is supported/up to date.
