When I (and my counter part) open Tool Box and go to use the
sockethead shoulder screw, it is listed but their is no model
icon. .. so it can not be drug onto the model to configure
andplace into the assembly.
When we looked it was was referencing a model for "socket headshoulder screw 2" and no bit map was there.
However, when I opened assemblies using socket head shoulder screwsthey worked, ... I assume because there is still a"socket head shoulder screw" model w/ bit map in thedirectory.
Instructions, please as this is an important group of screws for mydesign work.
I've repaired missing tumbnails for Toolbox by opening the fastener sldprt directly, zooming it to the desired view, rebuild, save, and close.
You will probably find the fastener in C:\Program Files\Common Files\Solidworks 2007 Data\Browser\ansi inch\bolts and screws
(The 2007 is unique to my system because of the way I did the install). If your toolbox database is installed on the network for shared access, then you'll need to follow that path instead.
