2 Replies Latest reply on Aug 17, 2018 4:56 AM by Sergio Monti
    Carrying revision table across multiple sheets
    Daniel Mapp
      We currently use our own company template for Solidworks drawings which contains its own revision table.
      Each time we start a new drawing from this template the revision table is in place and ready to go.
      I am currently working on some large scale installation drawings that need to be spread across multiple sheets.
      When I go to insert a new sheet in the drawing I locate the sddrt of our company template and select that but it does not pull through the revision table.
      What I would like is for a new shee fo the same format to be inserted with a duplicate of the revision table.
      Then when I update one revision table on one of the sheets it carries this update across to the revision table on all the other sheets.
      Is this possible?
