Noob here
Trying to get an edge relief on the corners of a couple of miter flanges I have done manually. I created these miter flanges using the edge flange & edit flange profile; due to the geometry of the part normal miter isn't possible?
Is this too complex for the edge relief command in the model view? Or is the only way to flatten, and use the "Corner-Trim" command (which doesn't change what it looks like in the model)?
Or is there another method?
Thanks, your help would be much appreciated.
J.K
Sorry I'm away from my SW right now, isn't there a Trim Side Bends command check box in the Miter Flange command?
