Looking to create flat pattern for a derived sheetmetal part, but the option is unavailable.
Hi Mike,
The way that I handle this in my SM designs is to make two configurations in your origin master model SM part - one flatten and one folded ( i.e configuring an unfolded feature as the last feature in your tree.) Once you've derived the part you can then edit the "list external references" (RMB on the stock feature ) and change the state of the derive stock feature to "flattened" configuration.
Mark
Use Convert to Sheet Metal on the derived part file. It will add all of the bends and bend lines, and let you flatten the derived part independent of the original.
Do a search in the knowledge base for SPR# 196295 and add your vote.
