Hello, everybody,
I have an assembly of robotic arms with two subassemblies inside. Each subassembly has moving parts inside which are animated using angle mates.
The problem is that I can't animate the whole assembly using mates that are inside subassemblies - Solidworks either gives error while saving or animation disappears when you rebuild subassembly (because you change the mate value, internal subassembly data changes accordingly and it ruins the initial key point).
I have ran accross the same question but it had no solution despite long discussion.
https://forum.solidworks.com/message/248362
I wonder is there any means of doing it besides dissolving subassemblies into assembly?
Best regards and thanks in advance.
The general rule is that motion controls must be in the top assembly.
Dissolving sub assemblies is one way of achieving that.
Maybe there are other ways of defining the motion in your model.
