3 Replies Latest reply on May 16, 2014 9:36 AM by Patrick O'Hern
    How to get the General Table width  with API?
    Yong Ning
      Manual can set the General table width,
      API set General table width  → set columnwidth→ sum columnwidth.
      Hope, how to get general table withdth with API
      Sub ll1()
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
        Dim SwView As View, SwTable As TableAnnotation, SwAnn As Annotation
          Set SwApp = GetObject(, "SldWorks.Application")
          Set SwModel = SwApp.ActiveDoc
          Set SwDraw = SwModel
          Set SwView = SwDraw.GetFirstView
          Set SwTable = SwView.GetFirstTableAnnotation
          Dim X, Y, Z As Integer, Anch
          X = 25: Y = 5
          SwTable.AnchorType = 3
          Dim ColWidth As Double
          Dim SwFeat As Feature
          With SwTable        ''
              .Merge 0
              .Split 1, 13        ''
              For jj = 0 To .ColumnCount
                .SetColumnWidth jj, 0.02, 0
                ColWidth = ColWidth + .GetColumnWidth(jj)
              Next jj        ''
              For ii = 0 To .RowCount - 1
                 .SetRowHeight ii, 0.005, 0
              Next ii
              .BorderLineWeight = 2
          End With
          Do While Not SwTable Is Nothing
             Set SwFeat = SwTable.GeneralTableFeature.GetFeature
             Debug.Print SwFeat.Name, SwTable.Title
             Set SwAnn = SwTable.GetAnnotation
             'Debug.Print SwTable.Title
             'ss = SwTable.GetAnnotation.GetPosition
             SwAnn.SetPosition X / 1000, Y / 1000, 0
             'Stop
            Set SwTable = SwTable.GetNext
            X = X + ColWidth * 1000
          Loop
        • Re: How to get the General Table width  with API?
          Patrick O'Hern
          I don't think you can get the width of the entire table, but you can get the width of each column (which you already seem to be doing), and add them together.
                    TotalWidth = TotalWidth + ColWidth  'add this row
                  Next jj
              Yong Ning
              Thanks your tips.
              It seems only SUM columns width, there is no other way.
              Function SwTableFindMergeRng(SwTable As TableAnnotation, Rng As Range)
                 Dim TextFormat As TextFormat, oTextFormat As TextFormat
                 Dim oRng As Range, wFactor, Cc
                 Cc = Rng.Columns.Count
                 For ii = 1 To Rng.Rows.Count     ''
                    For jj = 1 To Rng.Columns.Count
                       Set oRng = Rng(ii, jj)
                       wFactor = oRng(1, Cc + 1)
                       With oRng
                          If .MergeArea.Count > 1 Then
                            If .Address = .MergeArea.Cells(1, 1).Address Then
                              'Debug.Print oRng.Address, oRng, oRng.MergeArea.Rows.Count, oRng.MergeArea.Columns.Count
                              SwTable.MergeCells ii - 1, jj - 1, ii - 1 + .MergeArea.Rows.Count - 1, jj - 1 + .MergeArea.Columns.Count - 1
                              SwTable.Text(ii - 1, jj - 1) = .Value
                              Set TextFormat = WidthFactorTextFormat(SwTable.GetCellTextFormat(ii - 1, jj - 1), oRng, wFactor, 1)
                              SwTable.SetCellTextFormat ii - 1, jj - 1, False, TextFormat
                          Else
                            With SwTable
                              If IsNumeric(oRng.Value) Then
                                .Text(ii - 1, jj - 1) = Format(oRng.Value, "0.0#")
                              Else
                                .Text(ii - 1, jj - 1) = oRng.Value
                              Set TextFormat = WidthFactorTextFormat(.GetCellTextFormat(ii - 1, jj - 1), oRng, wFactor, 1)
                            End With
                       End With
                       With SwTable
                              If Not TextFormat Is Nothing Then
                                 Select Case oRng.HorizontalAlignment
                                   Case xlLeft
                                     .CellTextHorizontalJustification(ii - 1, jj - 1) = 1
                                   Case xlCenter
                                     .CellTextHorizontalJustification(ii - 1, jj - 1) = 2
                                   Case xlRight
                                     .CellTextHorizontalJustification(ii - 1, jj - 1) = 3
                                 End Select
                       End With
                    Next jj
                    'Debug.Print Rng(ii, -1), Rng(ii, -1).Address, ii, jj
                    'Stop
                    SwTable.SetRowHeight ii - 1, Rng(ii, -1) / 1000, 0
                 Next ii
              End Function
