Re: Reload Sheet Format
Deepak Gupta May 15, 2014 3:31 AM (in response to Jeffrey Tongco)Jeff,
I don't think API has codes for the reload button yet. So the workaround is to set the sheet format to none and then switching back to same sheet format. I've not tested this method and not sure if this would delete notes, etc. from the sheet format.
Please vote for SPRs #:330668
Jeffrey Tongco May 15, 2014 6:28 PM (in response to Deepak Gupta)Deepak,
Yeah I have that kind of process. I copied some codes.
So I have 2 macro button.
First macro setting the sheet format to none
Second macro reloading my updated sheet format.
Cheers,
Deepak Gupta May 16, 2014 10:27 AM (in response to Jeffrey Tongco)Why don't you combine both of them OR share the codes/macro here and someone will help you out.
Jeffrey Tongco Jun 4, 2014 12:04 AM (in response to Deepak Gupta)this is the first code
' * PLEASE change the path/filename for the sheet templates (see below)
' * Macro changes the sheetformat (= the "paper" of your drawing) for
' * all sheets of the active drawing. You have to adjust the path and
' * the file names to the new sheet formats. After successfully changing
' * the sheetformat the drawing is saved with its current name.
' * ATTENTION: you CAN'T change the drawing template, this is not
' * possible. So with this macro you can't update document properties.
' * All sheet formats will be "userdefinied" after updating with this
' * macro. If you want to have the "standard" A-A0 formats and not
' * userdefinied you have to change the macro accordingly or use its
' * "compagnion" which reloads a standard sheettemplate
' * This macro is intended to be used with PAC4SWX for batch reloading
' * of sheetformats, in case you changed you sheetformat with a new
' * company logo, new title block layout or similar. But it will also
' * word if fired from the GUI (taskplaner not tested, but should work;
' * but I would like to see you using PAC4SWX instead of taskplaner ;-))
' * PAC4SWX - http://swtools.cad.de/prog_pac.htm
' * 17.12.2003 Stefan Berlitz
' * SolidWorks Solution Partner
' * Inoffizielle deutsche SolidWorks Hilfeseite
Sub ReloadSheetFormat()
Dim sheetformatpath(12) As String
Dim sheetformatdir As String
' ************ EDIT path and file name HERE ************************
' After editing the sheetformats delete the next line or comment it
'If MsgBox(msgtext(6), vbOKOnly, "Please Edit Macro") = vbOK Then End
' Path to directory with sheetformats
sheetformatdir = "C:\ProgramData\SolidWorks\SolidWorks 2013\lang\english\sheetformat\New Template\"
' path to the various sheet formats from A to A0, you may also use
' full pathnames, but if they are all in teh same subdir it's easier this way
sheetformatpath(0) = sheetformatdir & "temp_A.slddrt"
sheetformatpath(1) = sheetformatdir & "temp_av.slddrt"
sheetformatpath(2) = sheetformatdir & "temp_B.slddrt"
sheetformatpath(3) = sheetformatdir & "temp_c.slddrt"
sheetformatpath(4) = sheetformatdir & "temp_d.slddrt"
sheetformatpath(5) = sheetformatdir & "temp_e.slddrt"
sheetformatpath(6) = sheetformatdir & "temp_a4.slddrt"
sheetformatpath(7) = sheetformatdir & "temp_a4v.slddrt"
sheetformatpath(8) = sheetformatdir & "temp_a3.slddrt"
sheetformatpath(9) = sheetformatdir & "temp_a2.slddrt"
sheetformatpath(10) = sheetformatdir & "temp_a1.slddrt"
sheetformatpath(11) = sheetformatdir & "temp_a0.slddrt"
' already user defined
sheetformatpath(12) = sheetformatdir & "WS-A3.slddrt"
' ************************* EDIT END *******************************
Dim swApp As Object
Dim DrawingDoc As Object
Dim Sheet As Object
Dim Titel As String
Dim Datei As String
Dim temp As String
Dim pfad As String
Dim msgtxt As String
Dim Name As String
Dim paperSize As Long
Dim templateIn As Long
Dim scale1 As Double
Dim scale2 As Double
Dim firstAngle As Boolean
Dim templateName As String
Dim Width As Double
Dim Height As Double
Dim propertyViewName As String
Dim i As Long
Dim MySheetCount As Long
Dim SheetNames As Variant
Dim SheetProperties As Variant
Const swDocDRAWING = 3
Const swDwgTemplateCustom = 12
Const swDwgTemplateNone = 13
' attach to SolidWorks
Set DrawingDoc = swApp.ActiveDoc
If DrawingDoc Is Nothing Then
' check if document is open
MsgBox "No Drawing Open"
Exit Sub
If (DrawingDoc.GetType <> swDocDRAWING) Then
' check if document is a drawing
Exit Sub
' get sheet count and traverse all sheets to reload sheetfromat
MySheetCount = DrawingDoc.GetSheetCount
SheetNames = DrawingDoc.GetSheetNames
' reset error messages
msgtxt = ""
For i = 0 To MySheetCount - 1
' activate next sheet
If DrawingDoc.ActivateSheet(SheetNames(i)) Then
' attach to sheet object
Set Sheet = DrawingDoc.GetCurrentSheet
SheetProperties = Sheet.GetProperties
' first we have to set the sheet to use "no sheetformat", for SolidWorks
' wont reload a sheetformat if it is the same name as before
Name = Sheet.GetName
paperSize = SheetProperties(0)
' set NO SHEETFORMAT
templateIn = swDwgTemplateNone
scale1 = SheetProperties(2)
scale2 = SheetProperties(3)
firstAngle = CBool(SheetProperties(4))
' no sheetformat = no path
templateName = ""
' but we need the sheet size
Width = SheetProperties(5)
Height = SheetProperties(6)
propertyViewName = Sheet.CustomPropertyView
retval = DrawingDoc.SetupSheet5( _
Name, _
paperSize, _
templateIn, _
scale1, _
scale2, _
firstAngle, _
templateName, _
Width, _
Height, _
propertyViewName, _
True)
If retval = False Then
msgtxt = "Error" & vbCrLf
Else
' and now we set the new sheetformat; it is necessary to set
' USER DEFINIED sheetformat for SolidWorks will look for the
' standard templates temp_??.slddrt in your spefified folder
' if using the standard sheet sizes.
templateIn = swDwgTemplateCustom
' get correct sheetformat for this size depending on the
' papersize, this will allow aleady userdefined sheetformats
' to properly be reloaded
paperSize = GetSheetSizeFromPaperSize(Width, Height)
templateName = sheetformatpath(paperSize)
Name, _
paperSize, _
templateIn, _
scale1, _
scale2, _
firstAngle, _
templateName, _
Width, _
Height, _
propertyViewName, _
True)
' ERROR : can't load new sheetformat
msgtxt = "Can't Load" & templateName & vbCrLf
Else
' everything worked fine, no message here for automation
' save the document without backup
'If DrawingDoc.Save2(True) > 0 Then
' error saving file
' Fehler beim Speichern
' msgtxt = msgtxt & msgtext(5) & vbCrLf
'End If
Else
msgtxt = "Something" & Name & vbCrLf
Next i
'SetDraftingStandard
'SetCurrentLayer
'If Len(msgtxt) Then
' MsgBox msgtxt
'End If
DrawingDoc.ViewZoomtofit2
DrawingDoc.ForceRebuild3 False
Function GetSheetSizeFromPaperSize(SheetWidth, SheetHeight)
' Function returns the SheetSize constant based on the width and heigth
' useful for userdefined sheetformats
Const swDwgPaperAsize = 0
Const swDwgPaperAsizeVertical = 1
Const swDwgPaperBsize = 2
Const swDwgPaperCsize = 3
Const swDwgPaperDsize = 4
Const swDwgPaperEsize = 5
Const swDwgPaperA4size = 6
Const swDwgPaperA4sizeVertical = 7
Const swDwgPaperA3size = 8
Const swDwgPaperA2size = 9
Const swDwgPaperA1size = 10
Const swDwgPaperA0size = 11
Const swDwgPapersUserDefined = 12
If (Round(SheetWidth, 4) = 0.2794) And (Round(SheetHeight, 4) = 0.2159) Then
GetSheetSizeFromPaperSize = swDwgPaperAsize
ElseIf (Round(SheetWidth, 4) = 0.2159) And (Round(SheetHeight, 4) = 0.2794) Then
GetSheetSizeFromPaperSize = swDwgPaperAsizeVertical
ElseIf (Round(SheetWidth, 4) = 0.4318) And (Round(SheetHeight, 4) = 0.2794) Then
GetSheetSizeFromPaperSize = swDwgPaperBsize
ElseIf (Round(SheetWidth, 4) = 0.5588) And (Round(SheetHeight, 4) = 0.4318) Then
GetSheetSizeFromPaperSize = swDwgPaperCsize
ElseIf (Round(SheetWidth, 4) = 0.8636) And (Round(SheetHeight, 4) = 0.5588) Then
GetSheetSizeFromPaperSize = swDwgPaperDsize
ElseIf (Round(SheetWidth, 4) = 1.1176) And (Round(SheetHeight, 4) = 0.8636) Then
GetSheetSizeFromPaperSize = swDwgPaperEsize
ElseIf (Round(SheetWidth, 4) = 0.297) And (Round(SheetHeight, 4) = 0.21) Then
GetSheetSizeFromPaperSize = swDwgPaperA4size
ElseIf (Round(SheetWidth, 4) = 0.21) And (Round(SheetHeight, 4) = 0.297) Then
GetSheetSizeFromPaperSize = swDwgPaperA4sizeVertical
ElseIf (Round(SheetWidth, 4) = 0.42) And (Round(SheetHeight, 4) = 0.297) Then
GetSheetSizeFromPaperSize = swDwgPaperA3size
ElseIf (Round(SheetWidth, 4) = 0.594) And (Round(SheetHeight, 4) = 0.42) Then
GetSheetSizeFromPaperSize = swDwgPaperA2size
ElseIf (Round(SheetWidth, 4) = 0.841) And (Round(SheetHeight, 4) = 0.594) Then
GetSheetSizeFromPaperSize = swDwgPaperA1size
ElseIf (Round(SheetWidth, 4) = 1.189) And (Round(SheetHeight, 4) = 0.841) Then
GetSheetSizeFromPaperSize = swDwgPaperA0size
Else
GetSheetSizeFromPaperSize = swDwgPapersUserDefined
End Function
Jeffrey Tongco Jun 4, 2014 12:05 AM (in response to Jeffrey Tongco)this is the second code
Option Explicit
Dim Part As Object
Set swApp = New SldWorks.SldWorks
Set Part = swApp.ActiveDoc
Part.SetupSheet4 "Sheet1", 6, 12, 1, 1, False, _
"C:\ProgramData\SolidWorks\SolidWorks 2013\lang\english\sheetformat\New Template\WS-A3.slddrt", _
0.297, 0.21, "Default"
Part.EditSketch
Deepak Gupta Jun 4, 2014 1:03 AM (in response to Jeffrey Tongco)The best would be to set the template to NONE and then reapply the same format. I just tested it out and it seems to work.
What is location of your template and template name so that I can incorporate them in the macro for you.
Jeffrey Tongco Jun 4, 2014 7:44 PM (in response to Deepak Gupta)Really?It works on your PC.
The location is C:\ProgramData\SolidWorks\SolidWorks 2013\lang\english\sheetformat\New Template
And the file name is WS-A3.slddrt
I already replace the path in the code but what happens is when I click the macro button for that
the template is set to NONE afterwards nothing happens.
So I have the second macro to reload my new template.
I'll wait for the reply
Deepak Gupta Jun 5, 2014 5:46 AM (in response to Jeffrey Tongco)Jeff,
Try this macro. Please try it on sample files first.
This has been tested on SW2014 SP3 Win 7 x64. So in case you've lower version of SW, you may need to fix the reference libraries in the macro.
Jeffrey Tongco Jun 11, 2014 1:58 AM (in response to Deepak Gupta)Deepak,
I got error in in this part
I dont know why. I am using SolidWorks 2013 SP3
Cheers,
Jeffrey Tongco Jun 11, 2014 6:13 PM (in response to Deepak Gupta)Hey Deepak,
Finally, it works!!
Thank you very much for the help.
Till next time
Cheers,
Nicole Walden Jun 16, 2014 5:04 PM (in response to Deepak Gupta)How can we get it to also update additional sheets?
If i go to sheet 2 and use the macro, it takes me back to the first sheet.
Deepak Gupta Jun 17, 2014 4:23 AM (in response to Nicole Walden)Do you want to change all sheets OR only second sheet?
Nicole Walden Jun 17, 2014 2:17 PM (in response to Deepak Gupta)Just the active sheet if that's possible.
Deepak Gupta Jun 17, 2014 11:55 PM (in response to Nicole Walden)Try the attached one. Make sure you've changed the sheet format path and name. Don't forget to add \ at the end of the sheet format path.
P.S. I've added version for SW2013 and SW2014.
Nicole Walden Jun 18, 2014 1:33 PM (in response to Deepak Gupta)Deepak, you rock!
I might just have to find some more roller coasters to take you on, as a thank you :-)
Jeffrey Tongco Feb 8, 2015 10:45 PM (in response to Deepak Gupta)Hey Deepak,
How to change the codes so that I could change all sheets in the drawing?
Jeffrey
Deepak Gupta Feb 8, 2015 10:54 PM (in response to Jeffrey Tongco)Check this one for all sheets: Re: Reload Sheet Format
Jeffrey Tongco Feb 9, 2015 1:06 AM (in response to Deepak Gupta)Deepak,
I think that version is for 2014.
I'm getting an error for it.
How do you change it for 2013 version.
Cheers
Deepak Gupta Feb 9, 2015 1:25 AM (in response to Jeffrey Tongco)Change the macro references to SW2013. Follow this video Fix-Update SOLIDWORKS Macro References
Jeffrey Tongco Feb 9, 2015 1:34 AM (in response to Deepak Gupta)Deepak,
Video was very helpful thanks.
But the macro does not perform the function that reload all drawing sheets.
How is that?
Cheers,
Deepak Gupta Mar 6, 2015 11:24 AM (in response to Jeffrey Tongco)Can you upload one sample drawing with older sheet format and your new sheet format that I can test/check the macro on.
Peter Larsen Sep 19, 2017 2:58 AM (in response to Deepak Gupta)Hi Deepak,
These macros work great with SW 2017 but I noticed that a couple of drawing sheet properties get changed as well:
1. Type of projection: Changes from First angle to Third angle.
2. Zone Parameters Tab -> Region: Changes from Sheet to Margins (do not know exactly what this is used for, though).
Any chance you know why this happens?
Thanks in advance.
Regards
Peter
Deepak Gupta Sep 19, 2017 2:53 PM (in response to Peter Larsen)If you have all drawings in First angle, then change False to True in both of these lines
'Set the sheet format to NONE
swModel.SetupSheet5 swSheet.GetName, swDwgPapersUserDefined, swDwgTemplateNone, vSheetProps(2), vSheetProps(3), False, "", 0.4318, 0.2794, "Default", True
'Reload the sheet format from the speicifed location
swModel.SetupSheet5 swSheet.GetName, swDwgPapersUserDefined, swDwgTemplateCustom, vSheetProps(2), vSheetProps(3), False, sTemplatePath & sTemplateName, 0.4318, 0.2794, "Default", True
I'll check the other issue and let you know.
Peter Larsen Sep 21, 2017 9:45 AM (in response to Deepak Gupta)Thank you very much Deepak!
Looking forward to the reply about the 2nd issue.
I have been trying without luck to modify the attached macro (made by you) to only reload the active sheet since I have to exclude sheets with certain names.
Would it be possible for you to modify it, so it only reloads the active sheet or even better, exclude sheets with specific name(s)?
Maybe I am asking for too much?
Regards
Peter
Deepak Gupta Sep 21, 2017 10:08 AM (in response to Peter Larsen)Peter Larsen wrote:
Both of these are possible.
Peter Larsen Nov 24, 2017 7:09 AM (in response to Deepak Gupta)Hi Deepak,
Did you get a chance to look at my 2nd point?
2. Zonejavascript:; Parameters Tab -> Region: Changes from Sheet to Margins (do not know exactly what this is used for, though).
It was about the attached macro where a drawing sheet setting is changed.
Besides that, are there any other risks/ changes that this macro does besides updating the active drawing sheet format? I would like to be 100% sure before I start using it.
Thank you very much.
/Peter
Deepak Gupta Nov 25, 2017 3:35 AM (in response to Peter Larsen)Peter Larsen wrote:
Sorry for the delay on getting back to you. Check this video about zone and their usage SOLIDWORKS Drawing Zones
Macro do not change the zone settings but it will drive that setting from the new sheet format (which is being used to replace the older one)
I've not seen any issues in using this macro but still advise to use on some sample files to be sure.
Garret Hansen Sep 17, 2014 3:55 PM (in response to Deepak Gupta)Hello Deepak,
I tried your macro and it works great for sheet one but it won't reload the sheet format of sheet 2 and so on. Even if I goto sheet 2 and run the macro it jumps back to sheet 1 and reloads the format for that sheet only.
Garret
Deepak Gupta Sep 18, 2014 5:48 AM (in response to Garret Hansen)Check this one: https://forum.solidworks.com/message/449388#449388
Deepak Gupta Mar 10, 2015 1:02 AM (in response to Jeffrey Tongco)You need to change the template path/name in the macro and save that. And when you run the macro it asks you to select a folder which contains the drawings whose drawing format you need to change. Once you select the folder,macro will open each drawing file in that selected folder and will updated the sheet format.
Jeffrey Tongco Mar 10, 2015 2:26 AM (in response to Deepak Gupta)Hey,
I've done what you instructed.
The macro process for each sheet but when you look at it while it is processing, the sheet content does not change and the drawing shut down.
Deepak Gupta Mar 10, 2015 2:42 AM (in response to Jeffrey Tongco)It will open, process and close the drawing and then move to process next drawing. Once the macro has updated all the drawings, did you checked those drawing by opening again.
Jeffrey Tongco Mar 10, 2015 3:20 AM (in response to Deepak Gupta)Ooh that's why.But when I checked the drawing all the drawings did not change.
Deepak Gupta Mar 10, 2015 4:31 AM (in response to Jeffrey Tongco)Can you add the upload updated macro, one drawing with older sheet format and the new sheet format.
In case you can't upload all then do upload the updated macro so that I can verify the changes made.
Jeffrey Tongco Mar 10, 2015 4:38 AM (in response to Deepak Gupta)I uploaded the macro updated.
Old sheet WS-A3-copy.slddrt
New sheet WS-A3.slddrt
Cheers,
WS-A3.slddrt.zip 81.3 KB
WS-A3 - Copy.slddrt.zip 88.2 KB
Deepak Gupta Mar 10, 2015 5:12 AM (in response to Jeffrey Tongco)The changes are correct and macro worked perfectly for me. Can you please verify the drawings again.
Please note that if you're older sheet format and new sheet format have same name then the macro won't work.
Jeffrey Tongco Mar 10, 2015 7:35 PM (in response to Deepak Gupta)It works now on my PC.
I use same name that's why it doesn't work.
Much appreciate your work.
Cheers,
Will Brumas Sep 6, 2017 9:20 AM (in response to Deepak Gupta)Hey Deepak,
I am replying to an old message here..but I am trying to use this macro to update all the sheets in my drawing. It's currently only updating the first sheet. Any suggestions?
Deepak Gupta Sep 6, 2017 10:54 AM (in response to Will Brumas)Will use/try the macro from this post: https://forum.solidworks.com/message/449388#449388
Patrick O'Hern May 15, 2014 9:50 AM (in response to Jeffrey Tongco)You probably just need to set the sheet properties using the existing values. This should reload the new template (I haven't tested this theory though.)
Check out this example from the help file: http://help.solidworks.com/2013/English/api/sldworksapi/Get_and_Set_Sheet_Properties_Example_VB.htm
Take out these lines:
' Switch projection property
bFirstAng = vSheetProps(4)
vSheetProps(4) = Not bFirstAng
That should get the existing sheet properties, and then reapply them but with an updated template.
Jeffrey Tongco Jun 4, 2014 12:06 AM (in response to Patrick O'Hern)There is an error with that code.
I dont know why.
Cheers
Poornakkumar Palanisamy Jun 4, 2014 12:51 AM (in response to Jeffrey Tongco)I think " we want to do manually", Macro will not suitable for this
Peter Larsen Nov 27, 2017 8:23 AM (in response to Jeffrey Tongco)Thanks, Deepak! I know you are a busy man!
But I must say that there is something happening when using the macro. It does change the Region from Sheet to Margins.
When I update manually with same sheet format it does not change to Margins. Maybe it somehow resets that setting...?
However, it doesn´t matter - I can still use the macro as it currently is.
Thanks again!
/Peter
Deepak Gupta Nov 27, 2017 1:41 PM (in response to Peter Larsen)Peter Larsen wrote:
I set the zone as needed and then saved out the new sheet format. And then using macro didn't changed that setting.
If you can share your files I can try to check those settings on your files..
Peter Larsen Jan 5, 2018 9:11 AM (in response to Deepak Gupta)Hi Deepak,
Finally, here are some test-files where you test if this also happens to you:
That Sheet property "Region" changes from "Sheet" to "Margins" when using the attached macro.
many thanks.
/Peter
Test-files.zip 214.4 KB
Deepak Gupta Jan 6, 2018 8:38 AM (in response to Peter Larsen)Peter, I do not see anything in the macro that would change it. Can you please report this to your VAR?
Peter Larsen Jan 10, 2018 1:47 AM (in response to Deepak Gupta)Thanks, Deepak - I will contact my VAR.
/Peter
Ricky Graber Oct 30, 2018 3:44 PM (in response to Peter Larsen)Did you resolve this issue with your VAR? I'm on SolidWorks 2017 SP5 and I am fighting this same issue. When running the macro, under zone parameters my region changes from Sheet to Margins which messes up my zones. I double checked my templates and it only does this when running it through the macro.
Garret Hansen Feb 12, 2018 6:51 PM (in response to Deepak Gupta)Hello Deepak,
I am trying to convert this macro into a task so that I can have it reload all the sheet formats during a transition. I am having trouble with the code to check out the file and then check it back in afterwards. Any suggestions?
Garret
Garret Hansen Feb 13, 2018 6:36 PM (in response to Garret Hansen)Okay I figured it out. If anyone is interested I have attach the code below that you will need to paste into the task script window.
Thanks for the help and sharing your code.
Garret Hansen Feb 14, 2018 2:48 PM (in response to Deepak Gupta)No worries. I couldn't done it without the help and resources on this forum.
MARCO TULIO RAMOS FILHO Mar 7, 2018 2:09 PM (in response to Garret Hansen)Hi Garret!
Thanx for the feedback and sorry for the absence!
