Removing Reference from Item
Question asked by Ben Molitor on May 13, 2014
I am trying to remove a reference from an Item. My code works fine when I add a Reference to the Item through code.
But when I add a reference to an Item manually through the Item Explorer, I am not able to Remove this Reference. Any Ideas?
    Private Function Item_RemoveFile(ByRef Item As IEdmItem, FileName As String, FileID As Integer) As String
            Dim RemoveRef(0) As EdmItemRef
            Dim refFlags As Integer = EdmRefFlags.EdmRef_File
            Dim ExistingRefs() As EdmItemRef = Nothing
            ' Get Existing References
            Item.GetReferences(refFlags, ExistingRefs)
            For Each ExistingRef As EdmItemRef In ExistingRefs
                If ExistingRef.moNamePathOrID = FileID Then
                     ' Found Reference
                    RemoveRef(0) = ExistingRef
                    ' Remove Reference
                    Item.UpdateReferences(Nothing, RemoveRef)
                    Item.Refresh()
                    ' This Function Checks the Item Back In
                     Update_ItemStatus(Item, True, "Removed File Reference")
                    Return ""
            Next ExistingRef
