Rename multiple equations in multiple parts?
Question asked by J. R. on May 13, 2014
Hi all,
I am working on top down design. There are many parts referencing to Global Variables of Master Part.
I decided to move all these Global Variables to a dimensions in a sketch.
So, every part should now reference like ="Plywood thickness@Sketch1@Master Part.sldprt" (dimension of a sketch) instead of ="Plywood thickness@Master Part.sldprt" (Global Variable).
However, naturally, all references are broken, and I have to rename each one by hand by just adding "@Sketch1" to each broken equation in every part.
Problem is that there is like 100 parts and around 250 broken equations.
I need to automate this renaming somehow. If it were one big part, I could export equations to .txt file, edit it with Notepad (Replace command would work very well). However, since most parts have like 2-3 broken equations, it is not worth the time. However, renaming each by hand will take me most of the day.
How can I rename all these equations at once in these multiple parts? I just need to replace "@Master Part.sldprt" to "@Sketch1@Master Part.sldprt" in EACH equation, no exceptions.
How can I do this? Maybe a macro?
