BMBrian Mick13/05/2014
I have a macro that makes new drawings, and it saves them per a part number I am supplying with a message box.  If I make an error, the macro will over-write existing files.  I do not want it to do this.
I found this code in a previous discussion:
If System.IO.File.Exists("K:\Models\" + FileName + ".SLDDRW") Then
    MsgBox ("File Already Exists")
    End
But it gives me "Compile Error: Method or data member not found"
I am using the SaveAs method from the SldWorks.ModelDoc2 object.  Is there a way to prevent overwriting existing files?
Thanks so much!
