MOLDING HELP
Question asked by Charlie Plant on May 11, 2014
Latest reply on May 11, 2014 by Charlie Plant
I'm still fairly new to solidworks and need help with a problem I am having.
Im making component housing using a laser cutter. The housing is made up from 2mm thick sheet material which is layered up.
each layer is different contouring the components within.
I've been succesfull so far with 3 components, however this last is prooving difficult.
I have been modeling the components roughly with the right size dimensions and placement. I then use the molding tool to make a female of the component.
The next step is to hide the original component, leaving just the cavity which I split up into the different layers.
Then export lines as DXF.
So all i need is a cavity mold of my component. As im a novice I dont know where im going wrong...
Any help would be greatly appreciated as im working on a short deadline.
