I have tried modeling the attached part, and need both 45 deg. flanges to be the same
thickness (.09 in.) as the main body. The dimensions already given should remain
if possible. Any help will greatly appreciated.
Rich
Message was edited by: Rich Chappell
I think for this particular part the sheet metal tools would be best. If you are willing to start over, you could do the first flat face as a single Base Flange/Tab, then use the Edge Flange tool to bring out each of the 45 degree faces (there's a box where you can specify the angle of the Edge Flange).
