6 Replies Latest reply on May 23, 2014 2:21 PM by Checkcheck Master
    Try to open a Part or Assy invisible or in Background
    Checkcheck Master
      Hi there,
      With a drawing open I start a macro who opens a Part or Assy to get for example the BoxSize from the model.
      I like to open te Part or Assy invisible or in Background, I don't have/don't like to see this operation.
      I've tried:
                  ' Allow SolidWorks to run in the background
                  ' and be invisible
                  swApp.UserControl = False
                  ' If the following property is true, then the
                  ' SolidWorks frame will be visible on a call to
                  ' ISldWorks::ActivateDoc2; so set it to false
                  swApp.Visible = False
                  ' Keep SolidWorks frame invisible when
                  ' ISldWorks::ActivateDoc2 is called
                  Dim pFrame As Frame
                  Set pFrame = swApp.Frame
                  pFrame.KeepInvisible = True
      And Reverse:
                  ' Show SolidWorks frame and SolidWorks
                  pFrame.KeepInvisible = False
                  swApp.Visible = True
      But I can't get it to work correctly, I still can watch the 'opening file' operation.
      Anyone knows how to handle this ?
      Greetings,
      Check Master
        • Re: Try to open a Part or Assy invisible or in Background
          Artem Taturevych
          You need to use SldWorks::DocumentVisible method in this case. Like following:
          'Set to not show the opening operation for next opened parts and assemblies
          swApp.DocumentVisible False, swDocumentTypes_e.swDocPART
          swApp.DocumentVisible False, swDocumentTypes_e.swDocASSEMBLY
          'TODO:Open Document
          'Restore flag otherwise all documents will be opened invisibly
          swApp.DocumentVisible True, swDocumentTypes_e.swDocPART
          swApp.DocumentVisible True, swDocumentTypes_e.swDocASSEMBLY
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
              Checkcheck Master
              Thanks Artem for your reaction !
              I've tried your code and study the API help, but still I can see the part opening.
              swApp is defined and set as:
              Dim swApp                   As SldWorks.SldWorks
              Dim swModel                 As SldWorks.ModelDoc2
              Dim swDraw                  As SldWorks.DrawingDoc
              Dim swView                  As SldWorks.View
              Dim bRet                    As Boolean
              Set swModel = swApp.ActiveDoc
              Set swDraw = swModel
              This is how I open the part, activate and switch to the right configuration:
              Set swModel = swApp.OpenDoc6(ModelFromDrawingView, nDocType, swOpenDocOptions_Silent, Data.ConfigName, nErrors, nWarnings)
              Set swModel = swApp.ActivateDoc2(ModelFromDrawingView, True, nErrors)
              swModel.ShowConfiguration2 (Data.ConfigName)
              Any idea what's going wrong ?
              Greetings,
              Check Master
