I've created a weldment part using a weldment profile, some basic extrustions/cuts, and an inserted part. For the cut-list item generated from the inserted part, is there any way to link the cut-list properties to the custom property embedded in the inserted part? For example, for the weldment profile-based cut-list items, the description is imported from the weldment profile sketch file. Is there any similar way to import the description custom property from the inserted part? Even if it was just a one-time import (as opposed to a parametric linking), I'd still be fine with that.
Sally
Edit your Inserted Part feature and select Custom Properties. The Custom Properties of the original part will appear as Cut List properties in the new file.
