i have a sheet metal assembly 4 parts. when i bring that into another drawing it shows up in the bom as all the parts, why doesnt it come in as one part?
i think i know what hppened, this box gets handles welded on to it as an option so i made a configuration with the handles. the problem is when i make a drawing to put the handles on the box shows as parts instead of just the box. i think if i made an assembly to put the handles on it would work unless there is a way to leave the handles in the box drawing as a configuration and have it show as 1 part in the handle assembly drawing.
I'm confused. You said you have a sheet metal assembly. Why shouldn't the BOM show each part? The only way I would expect a BOM to show only one part is if you had a multi-body part instead of an assembly.
The BOM will produce all the parts that make up the assembly.
