Section View
Question asked by Chris Champions on May 11, 2014
Latest reply on May 12, 2014 by Keith Parker
Not sure if I should post question here or in the assembly
When I use "section view" feature in the assembly to  view the models and it works ok
However, if I select a part in the assemby and open - The part is also "sectioned" same as it's seen in the assembly unless I edit a feature or sekctch to see the whole model
Is this a default setup or there is an option I can change so part is open and not sectioned
Thank you for any help
