2 Replies Latest reply on Jun 3, 2016 8:26 AM by Yong Ning
    Why can only delete a General Table
    Yong Ning
      SwSubFeat.Select False
      editdelete → can be delete One General table
      SwSubFeat.Select True
      editdelete  →  don't delete the General table
      Select many Feature of GeneralTableFeature, but don't delete General table.
      follow code
          Dim SwApp                                   As SldWorks.SldWorks
          Dim SwModel                                 As SldWorks.ModelDoc2
          Dim SwFeat                                  As SldWorks.Feature
          Dim SwSubFeat                               As SldWorks.Feature
          Dim sFeatType                               As String
          Set SwApp = Application.SldWorks
          Set SwModel = SwApp.ActiveDoc
          'Debug.Print "File = " & SwModel.GetPathName
          Set SwFeat = SwModel.FirstFeature
          Do While Not SwFeat Is Nothing
              'Debug.Print SwFeat.Name, SwFeat.GetTypeName
              Set SwSubFeat = SwFeat.GetFirstSubFeature
              Do While Not SwSubFeat Is Nothing
                  'Debug.Print SwSubFeat.Name, SwSubFeat.GetTypeName
                  If SwSubFeat.GetTypeName = "GeneralTableFeature" Then
                     SwModel.EditDelete
                  Set SwSubFeat = SwSubFeat.GetNextSubFeature
              Loop
              Set SwFeat = SwFeat.GetNextFeature
          Loop
      Hope , Select Many General Table → delete many general table
        • Re: Why can only delete a General Table
          Artem Taturevych
          Try
          SwModel.Extension.DeleteSelection2 swDeleteSelectionOptions_e.swDelete_Absorbed
          instead of
          SwModel.EditDelete
            Yong Ning
            Private Sub del20160603()
               Dim Xls As Excel.Application, Rng As Range
                   Set Xls = GetObject(, "Excel.Application")
                   Set Rng = Xls.Selection
               Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
               Dim SwSelMgr As SelectionMgr
                     Set SwSelMgr = SwModel.SelectionManager
               Dim SwGenTabFeat As GeneralTableFeature
                     Set SwGenTabFeat = SwSelMgr.GetSelectedObject5(1)
               Dim SwTabAnn As TableAnnotation
                     Set SwTabAnn = SwGenTabFeat.GetTableAnnotations(0)
                     delGeneralRowCol SwTabAnn
                     MergeRngToSwAnn Rng, SwTabAnn
            Function MergeRngToSwAnn(Rng As Range, SwTabAnn As TableAnnotation)
               'Debug.Print SwTabAnn.GeneralTableFeature.GetFeature.Name
               Dim AnnRow, AnnCol
                  With SwTabAnn
                     AnnRow = .RowCount: AnnCol = .ColumnCount
                  End With
               Dim RngRow, RngCol, Rr, Cc, ii, jj, Ccc As Double, ll As Double, Str, Ss
                  RngRow = Rng.Rows.Count
                  RngCol = Rng.Columns.Count
                  Rr = RngRow - AnnRow
                  If Rr > 0 Then
                       For ii = 1 To Rr
                          SwTabAnn.InsertRow 1, ii
                       Next ii
                  ElseIf Rr < 0 Then
                       For ii = 1 To Abs(Rr)
                          SwTabAnn.DeleteRow 0
                       Next ii
                  Cc = RngCol - AnnCol
                  If Cc > 0 Then
                       For ii = 1 To Cc
                          SwTabAnn.InsertColumn 1, 1, ii
                       Next ii
                  ElseIf Cc < 0 Then
                       For ii = 1 To Abs(Cc)
                          SwTabAnn.DeleteColumn 0
                       Next ii
               Dim C1, C2, R1, R2, TextFormat As TextFormat
                  Cc = Rng.Columns.Count
                  For ii = 1 To Rng.Rows.Count
                     For jj = 1 To Cc
                        If Rng(ii, jj).MergeCells Then
                          Ccc = Rng(ii, jj + 1 + Cc)
                          ll = 0
                          If Rng(ii, jj).Address = Rng(ii, jj).MergeArea(1, 1).Address Then
                             C1 = jj - 1
                             C2 = C1 + Rng(ii, jj).MergeArea.Columns.Count - 1
                             R1 = ii - 1
                             R2 = R1 + Rng(ii, jj).MergeArea.Rows.Count - 1
                             SwTabAnn.MergeCells R1, C1, R2, C2
                             SwTabAnn.Text(R1, C1) = Rng(R1 + 1, C1 + 1) '.Address(0, 0)
                             'Stop
                             If InStr(Rng(ii, jj), Chr(10)) > 0 Then
                                ll = 1.5
                             Set TextFormat = WidthFactorTextFormat(SwTabAnn.GetCellTextFormat(R1, C1), Rng(ii, jj), Ccc, ll)
                             SwTabAnn.SetCellTextFormat R1, C1, False, TextFormat
                        Else
                          SwTabAnn.Text(ii - 1, jj - 1) = Rng(ii, jj) '.Address(0, 0)
                          Set TextFormat = WidthFactorTextFormat(SwTabAnn.GetCellTextFormat(ii - 1, jj - 1), Rng(ii, jj), Ccc, ll)
                          SwTabAnn.SetCellTextFormat ii - 1, jj - 1, False, TextFormat
                     Next jj
                  Next ii
            End Function
            Function MergeRngToSwAnnBorderLine(Rng As Range, SwTabAnn As TableAnnotation)
               Dim AnnRow, AnnCol
                  With SwTabAnn
                  End With
                  If Rr > 0 Then
                       For ii = 1 To Rr
                       Next ii
                  ElseIf Rr < 0 Then
                       Next ii
                  If Cc > 0 Then
                       For ii = 1 To Cc
                       Next ii
                  ElseIf Cc < 0 Then
                       Next ii
                     For jj = 1 To Cc
                          ll = 0
                             C1 = jj - 1
                             R1 = ii - 1
                             'Stop
                                ll = 1.5
                        Else
                     Next jj
                  Next ii
                    'Stop
                    With SwTabAnn
                       .BorderLineWeight = 1
                       For jj = 1 To RngCol
                          .SetColumnWidth jj - 1, Rng(0, jj) / 1000, swTableRowColChange_TableSizeCanChange
                       Next jj
                       For jj = 1 To RngRow
                          .SetRowHeight jj - 1, (Rng(jj, 0) + 1) / 1000, swTableRowColChange_TableSizeCanChange
                       Next jj
                    End With
            End Function
            Function delGeneralRowCol(SwAnn As TableAnnotation)
               With SwAnn
                  For ii = .RowCount To 1 Step -1
                     .DeleteRow (ii)
                  Next ii
                  For jj = .ColumnCount To 1 Step -1
                     .DeleteColumn (jj)
                  Next jj
                  .Text(0, 0) = ""
               End With
            End Function
