1 Reply Latest reply on May 8, 2014 3:00 PM by Chris Christy
    Explanation of code
    Feroz Mahomed
      Below is a macro that was recorded and edited by me. It is used to mate to two parts with a distance mate.Could someone explain to me what all the zeros are for?
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Dim Dist As Double
      Set swApp = _
      Application.SldWorks
      Set Part = swApp.ActiveDoc
      Dist = InputBox(" Please enter distance in millimeters")
      'Dim myMate As Object
      Set myMate = Part.AddMate3(5, 1, False, Dist / 1000, 0, 0, 0, 0, 0, 0, 0, False, longstatus)
      'Part.ClearSelection2 True
      Part.EditRebuild3
        • Re: Explanation of code
          Chris Christy
          They are parameters for different types of mates, angle, limit, gear etc. Below is info on it from the API help.
          Function AddMate3( _
            ByVal MateTypeFromEnum As System.Integer, _
            ByVal AlignFromEnum As System.Integer, _
            ByVal Flip As System.Boolean, _
            ByVal Distance As System.Double, _
            ByVal DistanceAbsUpperLimit As System.Double, _
            ByVal DistanceAbsLowerLimit As System.Double, _
            ByVal GearRatioNumerator As System.Double, _
            ByVal GearRatioDenominator As System.Double, _
            ByVal Angle As System.Double, _
            ByVal AngleAbsUpperLimit As System.Double, _
            ByVal AngleAbsLowerLimit As System.Double, _
            ByVal ForPositioningOnly As System.Boolean, _
            ByRef ErrorStatus As System.Integer _
          ) As Mate2
          Parameters
          MateTypeFromEnum
          Type of mate as defined in swMateType_e
          AlignFromEnum
          Type of alignment as defined in swMateAlign_e
          Flip
          True to flip the component, false otherwise
          Distance
          Distance value to use with distance or limit mates
          Absolute maximum distance value (see Remarks
          Absolute minimum distance value (see Remarks)
          GearRatioNumerator
          Gear ratio numerator value for gear mates
          Gear ratio denominator value for gear mates
          Angle
          Angle value to use with angle mates
          AngleAbsUpperLimit
          Absolute maximum angle value
          AngleAbsLowerLimit
          ForPositioningOnly
          True positions the components according to the mating relationship but a mate relationship is not created and returned, false does not
          ErrorStatus
          Success or error as defined by swAddMateError_e
