Can anybody help me to merge the mirrored bodies. I have tried merge feature within mirror function and combine feature but I'm unsuccessful in both cases. The errors I get are:
1) Failed to merge the newly generated body with the work piece (in mirror feature)
2) Unable to create this feature because it would result in zero-thickness geometry (in combine feature after mirroring without ticking merge solids)
I have attached the file here so if you could help I would really appreciate!
the surfaces in the center just don't quite line up. if you are on 2013, the intersect feature will work to join the bodies. other wise you will probably have to delete the faces in the middle and knit the two surface bodies back together.
