I have a part with planes in it that I have created. These plans are datums for certain features. The planes will also be datums for certain components used later in an assembly. Lets say the planes are 10.000 apart. If I scale the part .500 the part does shrink but the planes still stay 10.000 apart. Why aren't the planes 5.000 apart. They were created with numbers that I input just like all the other features of the part? This makes my datums useless for my assembly.
You are right, planes don't scale, and neither do sketches it turns out. What you can do is instead of using a plane you can create a surface with the offsets you need. Then you can include the surface in the scale and use it for your mating. When you are done you can hide the surface.
