I'm wondering how to set up my auto-wire labeling system/equation so that my wires in my schematics are labeled in the appropriate avionics standard? On a quick look, it doesn't seem like there are enough user-customizable fields to assign into the equation that will "fill out" the information I need on the wire...
Thanks!
It's been awhile since I tried this, so I'm a bit foggy on the details, but here's what I think I remember:
The closest I got to making this happen was with a wire label symbol. We organize our wire diagrams to be system-centric by book, so the symbol included a user data attribute driven from the book properties.
Then I think I set up the wire styles to use the equipotential wire numbering scheme, so that all wires on the same equipotential would have the same numerical value. This is where passing and hyper-passing became really important.
So when you are numbering by equipotential, I can't remember if i found it as an attribute in the symbol editor... i think so. You're looking for one that refers to the equipotential segment. This would start with "A" and then increase on that equipotential for each wire segment.
Next part was the wire gauge attribute
Can't remember what I did for the suffix.
The most frustrating part was the lack of ability to concatenate and uniformly format all these separate pieces of data, so in order to prevent overruning text, I had to accept some gaps. The wire ID's looked a little like this:
1PWR001A 8 N
One thing that I think it's important to be aware of: As of 2014 SP2, SWE does not consider cable cores and wires together for uniqueness. So assuming you print your wire ids on the jackets of both wire and cable, it is completely possible that you would have a cable and a wire with the same ID.
Finally when we decided to ditch wire styles all together and use cables exclusively, the wire label approach no longer worked, which left us with manual wire/cable identification.
