RDRick Donnellon08/05/2014
OK we use use a lot of steel threaded inserts when using aluminum. When making a detail drawing we have to manually type in the thread insert make and number. So using the toolbox setting tool I copied and renamed the ANSI Metric standard and renamed it to "Steel Threaded Insert". I then edited the calloutformat.txt file, copying and renaming the standard to match the toolbox. I can add the make of the thread insert but isn there to way add a part number? I dosen't look like is since each size has a different part number.
