4 Replies Latest reply on May 8, 2014 3:44 PM by Danny Bradford
    Strange Macro problem hiding a row in a Drawing BOM Table
    Danny Bradford
      Greetings,
      Have created a Macro to create 10 rows above the selected rows (Thanks mostly to this forum therefore thanks to many of you!) and I would like for those same row to be hidden.
      In fact I shed the insert portion and am simply trying to hide a row in a BOM table. Code is below. The result (Solidworks 2013) is the system creates a phantom row and hides it. I know it is phantom because when I try to show the row it simply disappears. Quite strange!
      The code below has more than required because I just wanted to one "RowHidden" line of code to work. All the other stuff is to complete teh overall macro once this works. You can see that I am trying to simply hide the 3rd row.
      Option Explicit
          Dim swModel                 As SldWorks.ModelDoc2
          Dim swSelectionMgr          As SldWorks.SelectionMgr
          Dim swDrawing               As SldWorks.DrawingDoc
          Dim swAnnotation            As SldWorks.Annotation
          Dim swTableAnnotation       As SldWorks.BomTableAnnotation
          Dim firstRow                As Long
          Dim lastRow                 As Long
          Dim firstColumn             As Long
          Dim lastColumn              As Long
          Dim Do_It                   As Boolean
          Dim Hide_It                 As Boolean
          Dim i                       As Integer
          Dim m                       As Integer
          Dim InsertRow               As Integer
          Dim HideRow                 As Long
          Set swModel = swApp.ActiveDoc
          Set swSelectionMgr = swModel.SelectionManager
          Set swDrawing = swModel
          Set swTableAnnotation = swSelectionMgr.GetSelectedObject6(swSelectionMgr.GetSelectedObjectCount2(-1), -1)
          Set swAnnotation = swTableAnnotation.GetAnnotation
          swTableAnnotation.GetCellRange firstRow, lastRow, firstColumn, lastColumn
          'MsgBox "First selected cell's row     = " & firstRow
          'MsgBox "Last selected cell's row      = " & lastRow
          'MsgBox "First selected cell's column  = " & firstColumn
          'MsgBox "Last selected cell's column   = " & lastColumn
          For m = 0 To 0
            HideRow = CLng(firstRow + m)
            MsgBox "Row Hide placement  =" & HideRow
            'MsgBox "First Row  =" & firstRow
            swTableAnnotation.RowHidden(3) = True
          Next m
      Any help is greatly appreciated!!
      Danny Bradford
