3 Replies Latest reply on May 6, 2014 8:35 AM by Matthew Lorono
    Changing planes in drawings part
    Arsalan Shahid
      I am taking a complete Basic CAD course using Solid Works. I accidently created a drawing with extrusion in the wrong plane. Is there any way I can change the top plane to the front plane? I tried edit plane and it distorted the figure..
      Attached is the file. Thank You
      P.S. I do not have too much understanding in Solid Works, if there is a simple solution, I would appreciate it.
        • Re: Changing planes in drawings part
          Kelef Man
          hei'ya Arsalan, see the scrsht below,
          this would be the easiest-
          to rotate the body-
          Insert>Features>Move/Copy
          there is the alternative of selecting each sketch, then the plane icon,
          and reselecting the other plane/surface to move the sketch,
          and correcting the failed features one by one,
          which would also be a good exercise, as the sketches seem
          to need a bit of work on their accuracy
          ah well, hope this helps- have a good'n kelef
          edt.RE: other method
          have your original open>
          select>new >part>and
          then select>window>view vertically
          this will show your new and original side by side
          you can then use drag and drop, or Ctrl+c to copy
          of what you need, you will lose the relations
          and it can be a bit harsh but you still need to correct
          the (in)accuraccies
            Denny Peter
            Hi Arsalan
            I tried with your part, changing plane without editing other sketchs is not possible. Try what kelef suggested, or better to create a new one. Just to know,why you want to change the plane?
              Matthew Lorono
              You mention "drawing".  Is the issue in the drawing itself, or the model?  The drawing can look at whatever orientation of the model you like.
