10 Replies Latest reply on Nov 3, 2016 7:09 AM by Paul Mendes
    "Use in bill of materials" checkbox
    Mark Treadwell
      Is there a way to access the "use in bill of materials" checkbox in configuration settings via the API? There don't seem to be any properties of the configuration object that lead in this direction; the discussions at https://forum.solidworks.com/thread/77476 and https://forum.solidworks.com/message/102511 sounded promising but the documented switches don't include the one I'm looking for. Any suggestions would be greatly appreciated!
      -Mark
        • Re: "Use in bill of materials" checkbox
          Artem Taturevych
          The switch you are looking for is swConfigurationOptions2_e.swConfigOption_UseDescriptionInBOM
          so you can use something like this:
          swPart.EditConfiguration3 "Default", "Default", "", "", swConfigurationOptions2_e.swConfigOption_UseDescriptionInBOM
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          translationXpert – SolidWorks files language translator
          LinkedIn - SolidWorks API Group
              Mark Treadwell
              Thanks - I must have seen that when I looked at the autocomplete options under swConfigurationOptions2_e but it didn't click as the correct answer.
                Wim Block
                Hi Artem, Hi Mark,
                I'm having the same question as Mark, but don't really understand the solution provided by Artem...
                There is no such thing like a design table parameter to set this checkbox on/off?
                Maybe a short macro to run over the part sot set this checkbox on/off?
                Can u please explain a little to me?
                    Deepak Gupta
                    Try these codes
                    'Demonstrates how to select the active configuration description option "Use in bill of materials"
                    'Preconditions: Active file is a Part/Assy
                    Option Explicit
                    Dim swApp           As SldWorks.SldWorks
                    Dim swModel         As SldWorks.ModelDoc2
                    Dim swConfig        As String
                        Set swModel = swApp.ActiveDoc
                        swConfig = swModel.GetActiveConfiguration.Name
                        If (swModel Is Nothing) Then
                            MsgBox " Please open a Part/Assy document. "
                            End
                         If (swModel.GetType = swDocDRAWING) Then
                            End
                        swModel.EditConfiguration3 swConfig, swConfig, "", "", swConfigurationOptions2_e.swConfigOption_UseDescriptionInBOM
                        Wim Block
                        Hi Deepak
                        Thanks for you code
                        As I'm very unfamiliar with VBA, but I managed to copy paste your suggestion in right place (I'm good ). Made some Cfg's with design table an ran the macro working.
                        Just for providing you some feedback, I see that the DesTable member get's turned into a regular configuration, which is not a problem at this moment, but it would be more helpful (to me) to turn on the option for 'use in BoM' in all the part (asm?) config's and not just the one active... (I'm not less grateful for your quick and helpful response!)
                        I managed a workaround for my wanted description yesterday by concatenating a custom prp through a DesTable, so there's no further need to invest more of your time in this.
                        If ever needed, maybe we can pick this up again later! thx!
