Does anyone have a Report for EPDM that will identify SolidWorks files with external (outside the vault) references?
Or another way to search for files with External ref... might need Content (search index) type searching for this?
I know Update References will help with first check-in, but for some reason it cannot identify external ref after a file was checked-in without fixing them. I now block check-in if there are externals, but did not intially.
Thanks!
Brian
The database does not track references to files outside of the vault. Thus you aren't going to get a nice SQL report. You'll have to go to the actual files and read the external references from them. (Probably via the document manager)
