2 Replies Latest reply on May 7, 2014 2:35 AM by Yong Ning
    SwAnn.Select+EditDelete→Solidworks is fail.
    Yong Ning
      Why Run "SwAnn.Select True + SwDraw.EditDelete" code,Result is fail → Solidworks quit
      Why Run ".Extension.SelectByID2 + SwDraw.EditDelete" code, Result is currend.
      Code is
      Private Sub tDelDim()
        Dim Arr, Str
        Str = "凸台@JB4721Sketch,h1@JB4721Sketch,Delta1@JB4721Sketch,Delta2@JB4721Sketch,R@JB4721Sketch,D2@JB4721Sketch,D4@JB4721Sketch,D1@Alfa基准面"
        Dim SwApp As SldWorks.SldWorks, SwDraw As DrawingDoc
        Dim SwView As View, SwAnn As Annotation
        Dim SwDim As Dimension, DispDim As DisplayDimension
        Set SwApp = Application.SldWorks
        Set SwDraw = SwApp.ActiveDoc
        Set SwView = SwDraw.GetFirstView
        Do While Not SwView Is Nothing
           Set DispDim = SwView.GetFirstDisplayDimension
           Do While Not DispDim Is Nothing
              Set SwDim = DispDim.GetDimension
              oStr = SwDim.FullName
              oStr = Left(oStr, InStrRev(oStr, "@") - 1)
              Debug.Print oStr
              If InStr(Str, oStr) > 0 Then
                Set SwAnn = DispDim.GetAnnotation
                SwAnn.Select True
                SwDraw.EditDelete
              Set DispDim = DispDim.GetNext
           Loop
           Set SwView = SwView.GetNextView
        Loop
      Follow code is current,don't fail.
          SwDraw.Extension.SelectByID2 Str, "DIMENSION", 0, 0, 0, False, 0, Nothing, 0
          SwDraw.EditDelete
      Function DelDim(SwApp As SldWorks.SldWorks, SwDraw As DrawingDoc, SwView As View, Arr)
        Dim SwModel As ModelDoc2, Str
        Set SwModel = SwApp.GetOpenDocumentByName(SwView.GetReferencedModelName)
        Str = SwModel.GetTitle
        oStr = Left(Str, Len(Str) - 7)
        For ii = 0 To UBound(Arr)
          Str = Arr(ii) & "@" & oStr & "@" & SwView.GetName2
          SwDraw.EditDelete
        Next ii
      End Function
      Private Sub DelDim0502()
        Dim Arr, Str
        Arr = Array("凸台@JB4721Sketch", "h1@JB4721Sketch", "Delta1@JB4721Sketch", "Delta2@JB4721Sketch", "R@JB4721Sketch", "D2@JB4721Sketch", "D4@JB4721Sketch")
        DelDim SwApp, SwDraw, SwView, Arr
        • Re: SwAnn.Select+EditDelete→Solidworks is fail.
          Jacob Corder
          I use this below because it can be used for all selectable entities. I typed this in from memory so tbere may be spelling issues.
          you could also use in the Functions Arguments instead of ByRef Selobj() as object, you could also do Byref Objects as object which could be an array or just a single item. you would have to do a Typeof Check on it to see if its an array of items or just a single item.
          Public Function DeleteEntities(ByVal Modeldoc As ModelDoc2, ByRef selobj() As Object) As Boolean
                  Dim retBool As Boolean = False
                  If IsNothing(Modeldoc) = False And IsNothing(selobj) = False Then
                      Dim SelMgr As SelectionMgr = Modeldoc.SelectionManager
                      If IsNothing(selmgr) = False Then
                          Try
                              SelMgr.SuspendSelectionList()
                              Dim dwrapper(UBound(selobj)) As DispatchWrapper
                              Dim seldata As SelectData = SelMgr.CreateSelectData
                              For i = LBound(dwrapper) To UBound(dwrapper)
                                  dwrapper(i) = New DispatchWrapper(selobj(i))
                              Next
                              Dim selcount As Integer = selmgr.AddSelectionListObjects(dwrapper, seldata)
                              retBool = Modeldoc.Extension.DeleteSelection2(swDeleteSelectionOptions_e.swDelete_Absorbed)
                          Catch ex As Exception
                          Finally
                              selmgr.ResumeSelectionList()
                          End Try
                      selmgr = Nothing
                  Return retBool
              End Function
