I have a plastic part in SW 2014 Professional. Using "Mass Properties", the volume is reported as 76.93cm^3.
We have a seat of SolidWorks Plastics. I've run my part through analysis, and when the process is complete, the volume is reported as 77.87cm^3.
Why is there a discrepancy between the two? Is the latter the effective volume of the mesh, and not the original SW definition of part geometry? Regardless, why are they different?
(77.87-76.93)/76.93*100 = 1.22% greater volume in SW Plastics. This doesn't seem insignificant.
Bottom line, which should I use for cost estimating material usage? I've always trusted SW to get this right. SW Plastics has disturbed my trust (for now).
Thanks!
Hi Ken,
For different mesh size, you will see different Volume results (when you generate the Mesh, you can notice that cylindrical face is more or less 'perfect cylindrical', depends on Mesh Triangle Size). Try with your part with 10 and 2 units for Triangle Size > do the analysis and open Summary and Report to see the Volume. Small number for Triangle Mesh > more accuracy results but time to calculate the analysis is higher.
For Material (Polymer) properties, you can edit it and check the values: RMB on 'Polymer' > Open Database > in right side of Polymer window, you can edit and check any parameter.
Adrian Ilie
