I have an assembly with about 20 configurations and I made a sketch in that assembly that changes slightly with each configuration. I added a driven dimension in the assembly (not within the sketch) between points on the sketch and, as I had hoped, this dimension updates whenever I change the configuration. Now I want to delete that dimension, but if I delete it in the active configuration then when I change to another configuration the dimension is still there. If I go back to a config where I already deleted the dim then it will remain gone. So it seems like to get rid of the dimension completely I have to manually cycle through all of the configurations and delete the dimension in each of them. Is there a faster way? I feel like I should be able to just delete it once and have it gone.
In case it helps the dimension is called RD1@Annotations@XXX where XXX is the Assembly name.
Thanks in advance for the help.
