jonny vassdal
Importing Dxf problem
Discussion created by jonny vassdal on Feb 14, 2007
Latest reply on Feb 23, 2007 by John H
Hi.
I`m trying to import a dxf from jetcam. I`m trying to make a 3dpart from a 2d dxf that we use for machining the part.
But when i import the dxf into a part sketch i get alotof open counturs.
How do you make the sketch a closed countur so i can make a sheetpart from it?
Corner trimming is a bad idea as the sketch contains many shapes,and it will take forever. Probably be quicker to redraw thepart.
I`ve tried setting merge point on import to 0.1 mm without anyluck.
There must be an easy way.
Anybody???
