2 Replies Latest reply on May 5, 2014 12:42 PM by Mike Gann
    Read card variable ini EPDM Task Addin  - OnTaskRun subroutine
    Mike Gann
      I need to read a card variable in the onTaskRun procedure in a Task Add-in.
      In non-task add-ins I've been able to use this to read the revision variable from the data card.
                     Dim vars As IEdmEnumeratorVariable8 = poCmd.mpoExtra
                     Dim Revision As String = Nothing
                     vars.GetVar("Revision", "@", Revision)
      I tried this in the task add-in OnTaskRun procedure and the task fails. With only this line added the task will fail:
      Mike
        • Re: Read card variable ini EPDM Task Addin  - OnTaskRun subroutine
          Simon Turner
          You need to read the API Help for the EdmCmdData Structure.
          You will see that you get passed different data for each type of event that your addin handles.
          For OnTaskRun, mpoExtra points to the Task rather than a file.
          mlObjectID1 will be the ID of the file, so you need to get the IEdmFile5 object from that, and then you can set vars equal to that.
              Mike Gann
              Hi Simon -
              Thanks for the pointers, that is exactly what I needed! Here's what I ended up with (Revision and Status are read from the file card):
                      Dim FileID As Integer
                      Dim info As EdmCmdData
                      info = ppoData(0)
                      FileID = info.mlObjectID1         'Selected files ID
                      Dim vault As IEdmVault5
                      vault = poCmd.mpoVault
                      Dim FileObject As IEdmFile5
                      FileObject = vault.GetObject(EdmObjectType.EdmObject_File, FileID)
                      vars = FileObject.GetEnumeratorVariable
                      Dim Status As String = Nothing
                      vars.GetVar("Revision", "", Revision)
                      vars.GetVar("Status", "", Status)
              Thanks for the help!
              Mike
